FLEX 700: update to 5.30 and SSL VPN disconnecting problem
pka
pka Posts: 2 image  Freshman Member
After updating to 5.30, our SSL VPN connections are disconnected if there is no traffic over the VPN tunnel for a couple of minutes.
This means users are disconnected if they do some work outside the VPN tunnel, or take a short break.
The VPN connection stays open fine if we ping a host on the internal network every few seconds so there is traffic over the tunnel.
Has this problem been identified already?  How can we fix this?
«1
    PeterUK Posts: 4,333 image  Guru Member
    I think someone else has reported this too and I can confirm on my VPN300 V5.30 that the tunnel disconnects when idle but there is some oddness to it where one interface for a given zone is fine but another is not...
    Just a quick test avoid using zone “LAN” something odd is happening with that I think.
  • Fred_77
    Fred_77 Posts: 141 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Hi all
    after fw upgrade to 5.30 on my ATP i found this configuration enabled...
    as Bart Simpson says: "i didn't do it..."
  • Omnia
    Omnia Posts: 60 image  Ally Member
    @PeterUK have this Active?
  • Omnia
    Fred_77 said:
    Hi all
    I don't have this flag but the problem Is the same, After 1/2 minute the VPN disconnect by yourself
    edited May 2022
    Never had it set here too still with disconnects I try is set to 60 mins and see what that does.
    Edit still disconnects
    but having the client with a 2mins lease by DHCP  does something but I guess its no better then pinging down the VPN to keep alive
  • Omnia
    so if from the pc ping the gateway of the SSL VPN the tunnel remains active?
  • Omnia
    I confirm, if I ping the gateway of the VPN (192.168.200.1). the vpn tunnel remains active
  • Omnia
    after 30 minute we close ping, and the vpn tunnel still remain active
    With a USG40 on V4.71 the SSL VPN is stable on a given set port so their does seem to be a problem with V5.30.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,359 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @pka
    What SSL VPN SecuExtender version and OS version you are using?
    Can you provide the complete Monitor log screenshots of USG Flex 700 (during the SSL VPN connections disconnecting) and SecuExtenderHelper.log(you can find it in this path on your PC C:\SecuExtenderHelper.log) to us?
    Thanks.
