what is a max supported disk size for NAS325 v2 (firmware NSA325_4.81(AAAJ.1))
aldapooh
aldapooh Posts: 66 image  Ally Member
First Comment Friend Collector Second Anniversary Community MVP
edited May 2022 in Personal Cloud Storage
I have a very old NAS325 v2 (firmware NSA325_4.81(AAAJ.1)) which I still use, and recently one 3TB disk has died.
So I look for HDD replacement now and I wonder what is a max supported disk size for NAS325 v2 (firmware NSA325_4.81(AAAJ.1))?
On the other side - what would be your recommendation for HDD size so my old friend NAS325 v2 is not overloaded from CPU or Fan perspective?
Thanks, -a
PS and one more question - do you think it still make sense to invest in NAS325 disk replacement? what about firmware and security concerns?
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    edited May 2022
    The NAS325 v2 is end of life, for firmware and security concerns, you may consider to buy a new NAS.
  • aldapooh
    @ikubuf
    thanks. Understandable.
    Still I might use my old horse NSA325 for some sandbox scenario. So what is a maximum supported HDD size? Will 8TB work fine?
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    As far as I know the only size constraint enforced by the firmware is the max ext3 filesystem size of 16TiB. So as long as you don't use 2 disk raid0 or jbod, any disks <=16TB should be fine.
    The disk size has hardly any impact on CPU usage or heat dissipation. I would only be concerned about memory usage (cache and filesystem databases), but fortunately the 325 has a lot of RAM.
    When you are concerned about security, it is possible to install OpenWrt or Debian on that box.
