SecuExtender SSL disconnects after 2 minutes
Hello, I have problems in several ATPs when connecting through SecuExtender SSL.
They connect without problems, but after 2 minutes it disconnects for no apparent reason.
This happens with the latest update 5.30, and latest version of SSL SecuExtender 4.0.4.0 and on several devices, example ATP500 or ATP700.
What can be the motive?
Hi @Pedroj
this issue has been reported several times in the last period. Not so clear why, but it appears to occur when SSL VPN is in idle.
Someone found a workaround to keep alive the connection: continuos ping to 192.168.200.1 but obviously it can't be a solution. I believe zyxel is investigating.
Fred0 -
As far as i read on some posts from Zyxel representatives, newer version with fix of this bug has been reported available "next week". Hoping soon.
Hello, ok thank you very much for the info.I hope they don't take too long to fix.0
Hello...
... new release today...
https://community.zyxel.com/en/discussion/13502/zld-v5-30-wk20-firmware-release/p1?new=10 -
Did a 3 hour test with the new firmware seems stable0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
