Jason
GS1900-8HP PoE Issue
Hi @BjP,
I haven't received the tech support files from you via private message.
May you send again?
Thanks.0 -
I gave up in the end and bought a Netgear S350.0
Hi Jason,
i have the same problem. I tried to upgrade my GS1900-8HP to newest firmware 2.7 - after this i got the error message "POE init failed"
Please contact me and i can provice the tech files - thanks
BTW: No problem by upgrading my GS1900-10HP0 -
Hi, my problems are bigger as i thought.
I tried to use any other PORT or use another POE device - but since upgrading to 2.7 no one of my POE device is working.
Whats happend ?
Added Report:20Jan 01 2022 00:00:16PoEemergPoE Set CMD 13 failed21Jan 01 2022 00:00:16PoEemergPoE Set CMD 22 failed22Jan 01 2022 00:00:16PoEerrorPoE Failure: Set port power up mode23Jan 01 2022 00:00:16PoEemergPoE Set CMD 25 failed24Jan 01 2022 00:00:16SysteminfoSysinfo variable 'resetdefault' is set to value '0'25Jan 01 2022 00:00:15SystemnoticeRESTART: System restarted - Warm Start
Hi @ZyxelHamburg2023
Welcome to the Zyxel community!
Are you using V2.70 patch 3 firmware to upgrade your GS1900-8HP and then getting the "POE init failed" message?Zyxel Melen0 -
Hi Melen, yes of course. Downloaded the latest version from zyxel download center - named"GS1900-8HP_2.70(AAHI.3)C0"Zyxel_Melen said:Hi @ZyxelHamburg2023
- Upgrade process running pretty well
- after reboot "Error Message - POE INIT Failed"
=> Downgrade is possible but the problem still there:
- no error message unter 2.6 BUT
- no one POE Device will work - it looks like the POE Init "died" ?0 -
Hi @ZyxelHamburg2023,
Based on your feedback, your GS1900-8HP has PoE failure. Please check here to submit RMA request.
Zyxel Melen0 -
ok, already done - RMA created.Zyxel_Melen said:Hi @ZyxelHamburg2023,
Based on your feedback, your GS1900-8HP has PoE failure. Please check here to submit RMA request.0 -
I am thrilled.Already today the replacement device reached me.That is perfect customer service for me.I am glad to have chosen "Zyxel" products.THANK YOU0
Dear my Zyxel GS1900-10HP broke down the POE ports are no longer working.
It gives the message "POE INIT FAIL".
As it is out of warrenty I have opened it and found that a diode was broken on the PCB in the 3.3v switching power supply part that provides power to the Broadcom POE chip.
As a consequence of this TP14 doesn't measure 3.3v
I replaced the diode (B1100 SMD diode) and now my beloved switch is working 100% with POE.
For anyone out of warrenty and doesn't want to put this otherwise good switch in the trash I hope I could help.
Greetings
Tom
2
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
