ZyWall 110 will not boot up
Hi, try to restore the functionality of your device according to the following instructions.
maybe do a reset?0
Thanks, i will try that.jonatan said:Hi, try to restore the functionality of your device according to the following instructions.0 -
Thanks for the response.Nebula_CSO said:Hi @cavolo
You can make sure your serial cable is available for others device.
And Zywall110 default baud rate is 115200, so terminal setting must be the same.
My serial is working on other devices, but didn't use the rate 115200. i will try it, when i get back to the location where the ZyWall 110 is.0
- 588 USG FLEX H Series
- 476 News and Release
