XS1930-10 as a L3 WAN Router?
beadon
beadon Posts: 1 image  Freshman Member
edited August 2022 in Switch
The XS1930-10 seems to have the full capabilities of a L2 and L3 router, it even has a DHCP relay.  However, I cannot figure out how to configure a port as NAT and route accordingly.  Is there a basic guide to setting this up properly for one port to act as an IPV4 NAT to a specific VLAN ?
    PeterUK Posts: 4,411 image  Guru Member
    NAT is done by a router a switch can't NAT many MAC's for a LAN to go out a given WAN IP by a given MAC.
    If you make your client have the same MAC (and ideally the same the DHCP requests) you can (works on my GS2210) use VLAN to make the switch like a hub and not conflict their being the same MAC this does mean the clients are isolated.
  • Zyxel_Adam
    Zyxel_Adam Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    Hi @beadon,
    Welcome to Zyxel Community!
    As @PeterUK states that please configure your NAT on a router or a modem for your devices.
    Adam
