ZyWall 110 will not boot up
Hi, try to restore the functionality of your device according to the following instructions.
maybe do a reset?0
jonatan said:Hi, try to restore the functionality of your device according to the following instructions.0
Nebula_CSO said:Hi @cavolo
You can make sure your serial cable is available for others device.
And Zywall110 default baud rate is 115200, so terminal setting must be the same.
My serial is working on other devices, but didn't use the rate 115200. i will try it, when i get back to the location where the ZyWall 110 is.0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
