USG310 - L2TP VPN - GUI Error? - Unable to select VPN Connection
AaronReynoldsUK
in Security
I have a fully working IPSec and L2TP VPN on the firewall. Tested and used for 2yrs+.
Just upgraded to v4.72 (latest) firmware. Model is USG310.
GUI Page = VPN > L2TP VPN
Issue:
The drop-down for "VPN Connection" now contains "Please select on..." and the only option is "none".
Expected Behaviour:
The configured IPSec VPN should be selectable (was previously).
Notes:
Not sure if the requirements have changed or if this is a fault in the GUI.
Issue:
Expected Behaviour:
Notes:
Best Answers
Hi @AaronReynoldsUK,
Welcome to Zyxel community.
This is not expected behavior. Can you send me startup configuration file in PM for further checking?
Thanks.0 -
Zyxel_Cooldia said:Hi @AaronReynoldsUK,
Thanks.
Zyxel_Cooldia identified that I was incorrectly using "mode config" on the IPSec configuration (incompatible with/overriding L2TP on ZyXEL), once disabled the VPN Connection was again selectable in L2TP configuration.
Re check vpn connection and VPN gateway settings for L2TP VPN
Later versions (4.x) sometimes to not have any L2TP gateway/connection configured.You can re-enable them with a specific terminal command documented into a KB.1
Thanks.0 -
I'm not sure this applies, but if you can send a link to the KB, I can check it.mMontana said:Later versions (4.x) sometimes to not have any L2TP gateway/connection configured.You can re-enable them with a specific terminal command documented into a KB.0 -
Thanks.
Thank you.
I've PM'd you a redacted startup config.0 -
Thanks.
Is there any solution for this error or should we just throw Zywalls away?0
zyxel support ridiculous0
Hi @hgmrtn,
Please help to check if mode config is tick in VPN phase 2.Go to IPSec VPN > VPN Connection > RemoteAccess_L2TP_Wiz > Mode Config.Turn off "Enable Mode Config". Mode Config is for software IPSec VPN client (the green bow client).
Then you can find it appears on the drop-down list of L2TP > VPN Connection. On this page, IP Address Pool assigns IP addresses to L2TP VPN clients, so you don't need to configure Mode Config in VPN Connection > RemoteAccess_L2TP_Wiz.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
