USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
  • FunBizBun
    FunBizBun Posts: 7 image  Freshman Member
    Hi, I'm having very similar unstable wifi issues with my usg20w-vpn much like the OP. Is it possible to get access to this firmware as well?
  • Zyxel_Stanley
    Hi @FunBizBun
    I will send you the firmware by private message.
    Please has a check.
  • FunBizBun
    Thanks a bunch Stanley, hope this works :)
  • FunBizBun
    Hi Stanley,
    Is it normal to encounter the message:"Ajax communication failed" - after the firmware upload has been completed?
    I encountered that error, and re-uploaded the firmware again (just in case)...but the same message came up.
    Checking the firmware management page does show the firmware running as the one you sent, but unlike the OP, mine does not say USG60W - is this the exact firmware that he received? Thanks again!
  • Zyxel_Stanley
    Hi @FunBizBun
    I have sent you firmware by private message again. :)
  • Zolino
    Zolino Posts: 1 image  Freshman Member
    Hi, I'm having same wifi issues with usg20w-vpn. Is it possible to get access to this firmware as well?
  • Zyxel_Stanley
    Hi @Zolino
    Please has a check.
  • nikita
    nikita Posts: 5 image  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    I'm having similar problem after some days pwd seems not be valid anymore.
    When will you release the new official patched firmware?
    Thanks nIc
  • Zyxel_Stanley
    edited August 2018
    Hi @nikita
    I will send you the firmware by private message. Please has a check.
  • AOS
    AOS Posts: 1 image  Freshman Member
    Could I also have it? My USG20W is only 7 days old, running latest firmware, and wireless is non-responsive to changes.
