GTA5 and USG Flex 100
Do you have a rule like to allow LAN1 to WAN with all services?
If you only letting say port 53,80 and 443 outbound then the game will be blocked and you need to look at what the game needs. You might need some NAT inbound rules too.
Look in the firewall log and enable protocols to find the ports if inbound or outbound
How to Create a Port Forward in Your Router for Grand Theft Auto Online
Hi @Niro96
While this symptom occurring, can you check the Monitor log to see if there is any blocked or drop message? It's may a clue. You can navigate the Web-GUI path: Monitor->Log -> View Log
Thanks.
Hello, thanks for the reply. I have read in the log file and on the Internet which ports have to be activated. I set this up and tested it. Unfortunately, the error message remains. Acuh if I deactivate the firewall, this message comes up. It may be due to port forwarding. If I connect our old Draytek, the connection works. Unfortunately I don't know what I have to set in the USG. greetingMarcus0
Its like you need to NAT a port “Virtual Server” to the device likely UDP port 6672 and allow from WAN to LAN1
Many Thanks. I'll deal with it over the weekend and try it. I'll get in touch.
Is this correct so?
I have also a Switch GS 1920 8HP behind the USG Flex 100. Is there also a Firewall?0 -
Yes it should work now?
No, it dosent work.Even if I disable the security policies, this error comes. Is it the switch that is connected to the USG?The computer is connected to this switch. You can also set NAT in the switch.0
Attached is the log file during the error.
- 441 Beta Program
- 293 Service & License
