GTA5 and USG Flex 100
I don't get why its not working. Do you have ADP enabled?
I have now deactivated the firewall. Did not work. Then I disabled everything under Security Service. Then suddenly it happened. Firewall on again and everything gradually activated and tested. Everything is enabled except IPS is disabled. It's working right now. Let's see how it is tomorrow. The funny thing is. There are four servers of this game. Servers 2-4 worked. Server 1 not. It works now. I will report tomorrow.
The error was there again today without anything being changed on the USG. Yesterday went the game with the settings. Today I did the following steps. Firewall completely off. game doesn't work. security service off. All disabled. Replaced Telekom's DNS server with 8.8.8.8 under LAN 1. Then the game opened. Firewall back on, game restarted. Game opens. I don't know where the problem is. There is nothing in the log file when I start the game on the PC.ADP is enabled.greetingMarcus0
Hi @Niro96,Can you provide the device config file and the packets of wan and lan interfaces while the symptom occurs for us via private message for further checks? Thanks.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
