Replacement for the ZyXel P-871M VDSL2 Point To Point Modem
kwinz
in Home Router
we have been using ZyXel P-871M VDSL2 Point To Point Modem.
Where one P-871M device is switched to CPE mode and one device to C0 mode,
which gives you an Ethernet bridge over a single pair of 2km wire.
Unfortunately it looks like the P-871M has been discontinued in 2015.
Is there a successor or replacement for the P-871M?
Thanks in advance!
Thanks in advance!
Hello @kwinz
I don't think that Zyxel do this sort of device anymore, and their EOL list does not give a replacement.
I have not used them, but Planet seem to have a product called VC231GF that might do what you want, see https://www.planet.com.tw/en/product/vc-231gf?c1=broadband-communication&c2=xdsl-cpe&c3=vdsl2-bridge-modem
- The website even talks about how the VC-231GF can be set-up in CO or CPE mode.
I hope that this is helpful.
Kind regards,
Tony1
I have no relationship with Zyxel.
Due to the device you reported, I'd look for info on VMG4005-B50A.
https://www.zyxel.com/it/it/products_services/VDSL2-17a-Bonding-and-35b-Single-Line-Bridge-VMG4005-B50A/specifications
italian site but english specs.1 -
Hello @kwinz
Kind regards,
Tony1
- 588 USG FLEX H Series
- 476 News and Release
