ATP Geo-IP Filtering in Nebula
Hello @pcservice,Welcome to Zyxel Community!I suggest to have a positive list instead of a negative list.For example, if you have a virtual server on the local network, and you would like to only accept the IP addresses from North America to access it. You will need two rules.One is allow source: USA, Canada..., and another is block source: any. Please note that allow rule should has higher priority then the block rule.
- IP addresses from North America will match the first rule and be allowed to access.
- IP addresses from another continents will match the second rule and be blocked to access.
Regards,James0
- 603 USG FLEX H Series
- 481 News and Release
