Remove an internal HDD of a NAS540 and install it on a external USB case
MarkusDesk
Hello, if I remove a basic volume HDD from a NAS540 and put it on a external USB enclosure and connect it to another NAS540, how can I mount it to copy the files?
Find out which device node is used. Probably 'cat /proc/partitions' can tell you.Assuming the disk is sdd, you can mount it:mdadm --assemble /dev/md4 /dev/sdd3 --runmount /dev/md4 /path/to/mountpointWhen /dev/md4 is already in use (/proc/partitions or /proc/mdstat will tell you) choose a higher number.A warning: some (maybe most) USB to Sata converters do a logical sector size translation on disks >2TiB. If your enclosure is one of them, this will not work, as changing the sector size renders the partition table incompatible. You can see if this is the case with 'fdisk -l /dev/sdd'. It shows the logical sector size, which should be 512 bytes.On modern kernels it is possible to create a loopdevice with a deviating sector size:losetup --sector-size=512 --show -f /dev/sddnow you can treat /dev/loopXp3 as /dev/sdd3. But I doubt if either the kernel of the NAS5xx or the (busybox) implementation of losetup supports this.0
how to find out which device node is use? I'm quite blind about this stuffMijzelf said:Find out which device node is used. Probably 'cat /proc/partitions' can tell you.Assuming the disk is sdd, you can mount it:mdadm --assemble /dev/md4 /dev/sdd3 --runmount /dev/md4 /path/to/mountpointWhen /dev/md4 is already in use (/proc/partitions or /proc/mdstat will tell you) choose a higher number.A warning: some (maybe most) USB to Sata converters do a logical sector size translation on disks >2TiB. If your enclosure is one of them, this will not work, as changing the sector size renders the partition table incompatible. You can see if this is the case with 'fdisk -l /dev/sdd'. It shows the logical sector size, which should be 512 bytes.On modern kernels it is possible to create a loopdevice with a deviating sector size:cookie clickerlosetup --sector-size=512 --show -f /dev/sddnow you can treat /dev/loopXp3 as /dev/sdd3. But I doubt if either the kernel of the NAS5xx or the (busybox) implementation of losetup supports this.0 -
Hello, thanks for replying.With the command cat /proc/partitions, I get:8 32 7814026583 sdc
8 33 7814025543 sdc1With the HDD connected on the USB enclosure and with the fdisk -l command, I get:Disk /dev/sdc: 7.3 TiB, 8001563221504 bytes, 15628053167 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytesDevice Start End Sectors Size Type
/dev/sdc1 2048 15628053134 15628051087 7.3T Linux filesystemSo it seems to be 512 bytes, correct?Before I try the command mdadm, I want to make sure I don't mess with anything. After the mdadm and mount command, can I just umount it and remove the USB drive or do I need to issue another command?
@ybaumbach : 'cat /proc/partitions' shows you the disks, their partitions and sizes. If that is not enough to distinguish the USB disk, you could look at the difference without and with the disk plugged.@MarkusDesk : There is something wrong. If that disk contains a volume created in a NAS5xx, it should have 3 partitions, not just one.But yes, the sectorsize is correct. (Although I doubt the optimal I/O size is 512 bytes, but that won't affect the basic functioning)After umounting you can stop the array:mdadm --stop /dev/md4I don't think it actually matters, but it won't do any harm, and it look symmetric.2
Thanks for the answer
- 234 Nebula Ideas
- 6.7K Security
- 732 USG FLEX H Series
- 373 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 117 Security Highlight
