NR7101 new user questions
Just asking because Telia datacard in Sweden only supports 3G an 4G.
Tried sim in your phone???
So you did like this?
Yes the sim works with the phone at 5g
Done what you said no connection0 -
Are you sure it is a stand alone network?
If you change to auto and combine, does it connect to 5G and aggregate with 4G?
It is a not standalone network.
It connects with 5g and aggregates 4g frequencies
The same with the page you sent0 -
To summarize this
Please answer if any user of the device sees 5g aggregation under scc in the detailed cellular info page.
If so it is my problem.
You can´t lock 5G only with NSA.
You can lock one 4G frequency so it always connect that, i have locked my 7101 to B20 (800 mhz).
I see 2 more 4G under SCC info (B3,B7)......
Detailed info page?
Go to "System monitor/Cellular wan status" and change to 5 secs. update, scroll down and watch if you see something....
If your 7101 is a standard no NEBULA you can download and install attached beta firmware.
Ok
Thanks for your answers.
Forgive any mistakes.
I am as the title of the thread says a new user.1 -
My homepage shows 5 staples of 5 because of the strong 4G signal (B20 800mhz) i´ve locked.
Thank you for your answers
I am a new user1
- 588 USG FLEX H Series
- 477 News and Release
