NR7101 new user questions
2»
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    edited June 2022
    Just asking because Telia datacard in Sweden only supports 3G an 4G.
    Tried sim in your phone???
    So you did like this?
  • geo_al
    geo_al Posts: 16 image  Freshman Member
    Yes the sim works with the phone at 5g
    Done what you said no connection
  • SELBERG
    Are you sure it is a stand alone network?
    If you change to auto and combine, does it connect to 5G and aggregate with 4G?
  • geo_al
    It is a not standalone network.
    It connects with 5g and aggregates 4g frequencies
    The same with the page you sent
  • geo_al
    To summarize this
    Please answer if any user of the device sees 5g aggregation under scc in the detailed cellular info page.
    If so it is my problem.
  • SELBERG
    edited June 2022
    You can´t lock 5G only with NSA.
    You can lock one 4G frequency so it always connect that, i have locked my 7101 to B20 (800 mhz).
    I see 2 more 4G under SCC info (B3,B7)......
    Detailed info page?
    Go to "System monitor/Cellular wan status" and change to 5 secs. update, scroll down and watch if you see something....
    If your 7101 is a standard no NEBULA you can download and install attached beta firmware.
  • geo_al
    Ok
    Thanks for your answers.
    Forgive any mistakes.
    I am as the title of the thread says a new user.
  • SELBERG
    edited June 2022 Answer ✓
    My homepage shows 5 staples of 5 because of the strong 4G signal (B20 800mhz) i´ve locked.
  • geo_al
    Thank you for your answers
    I am a new user
