LTE7460 https://192.168.1.1 - can't reach the server
lavmax
Do a factory reset.0
Try a power off for a minute.
I had the same issue once on my NR7101.
White782 said:find the product specifications and the manual specifications of the ZyXEL UAG715.
The UAG715 went end of life by Zyxel in September 2013, see http://static.us.zyxel.com/pdf/2021/EOL-and-Warranty_Jan21_2021.pdf and there is no replacement listed.
Specifications available at https://www.cloudtechstore.com/ProductDetail?Id=26599959&IsVarstreet=true&LoadType=2&ResultAction=1
User guide for UAG715 at https://www.manuals.ca/zyxel/uag715/manual
Kind regards,
Tony0 -
To find router login IP on a windows computer, do as described.
- Press the Windows + R keys on your keyboard at the same time to open the Run window.
- Then type CMD into the search bar and click OK. You can also hit Enter on your keyboard.
- Next, type ipconfig and press Enter.
- You will see your router’s IP address next to the Default Gateway. Depending on your computer and the devices you have connected to your network, you might have to scroll down to see this.
1 - Press the Windows + R keys on your keyboard at the same time to open the Run window.
Hello @lavmax
Looking at the user guide at https://download.zyxel.com/LTE7460-M608/user_guide/LTE7460-M608_V1.00.pdf there seems to be more than 1 LED.
I have copied the table out below, which should help with your very first post question about flashing green LED and is it dead.
I hope that this is helpful.
Kind regards,
Tony0 -
The main problem is..... Can't reach the server with 192.168.1.1.0
One interest-bearing prepaid option from MetaBank is the ACE Flare Account. Optional savings accounts with annual percentage yields (APYs) of up to 5% and early direct deposits are exceptional features. You can’t get free withdrawals unless you meet certain Direct Deposit requirements and don’t waive the monthly fee. <a href="https://aceflare.shop/">https://aceflare.shop/</a>
-1 -
-1
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
