LTE7460 https://192.168.1.1 - can't reach the server
lavmax
lavmax Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
Green light flashes
Any ideas? Is it dead?
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Do a factory reset.
  • lavmax
    SELBERG said:
    Do a factory reset.
    The first thing I've done. No help (
  • SELBERG
    edited June 2022
    Try a power off for a minute.
    I had the same issue once on my NR7101.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited June 2022
    White782 said:
    find the product specifications and the manual specifications of the ZyXEL UAG715.
    Hello @White782
    The UAG715 went end of life by Zyxel in September 2013, see http://static.us.zyxel.com/pdf/2021/EOL-and-Warranty_Jan21_2021.pdf and there is no replacement listed.
    Specifications available at https://www.cloudtechstore.com/ProductDetail?Id=26599959&IsVarstreet=true&LoadType=2&ResultAction=1
    User guide for UAG715 at https://www.manuals.ca/zyxel/uag715/manual
    Kind regards,
        Tony
  • lavmax
    Sorry, how is this relevant?
  • SELBERG
    edited July 2022
    To find router login IP on a windows computer, do as described.
    1. Press the Windows + R keys on your keyboard at the same time to open the Run window.
    2. Then type CMD into the search bar and click OK. You can also hit Enter on your keyboard.
    3. Next, type ipconfig and press Enter.
      How to Find Your Routers IP Address on Windows
    4. You will see your router’s IP address next to the Default Gateway. Depending on your computer and the devices you have connected to your network, you might have to scroll down to see this.
  • tonygibbs16
    edited July 2022
    Hello @lavmax
    Looking at the user guide at https://download.zyxel.com/LTE7460-M608/user_guide/LTE7460-M608_V1.00.pdf there seems to be more than 1 LED.
    I have copied the table out below, which should help with your very first post question about flashing green LED and is it dead.
    I hope that this is helpful.
    Kind regards,
         Tony
  • SELBERG
    The main problem is..... Can't reach the server with 192.168.1.1.
  • One interest-bearing prepaid option from MetaBank is the ACE Flare Account. Optional savings accounts with annual percentage yields (APYs) of up to 5% and early direct deposits are exceptional features. You can’t get free withdrawals unless you meet certain Direct Deposit requirements and don’t waive the monthly fee. <a href="https://aceflare.shop/">https://aceflare.shop/</a>
