NWA1100-NH
NewledgeDee
in Home Router
I am trying to set up an old NWA1100-NH but couldn't access web configurator even after reset. Please help. Thank you.
Which version of firmware do you have?Are you trying to access via HTTP or HTTPS? Did you read the default ip address? Have you a DHCP server on your network?0
tried both - no success. default ip address - no success. no idea about DHCP server but my guess is no as it is connected straight to a router from a broadband supplier. please help. thank you.0
Hello @NewledgeDee
Looking at the user guide at https://download.zyxel.com/NWA1100-NH/user_guide/NWA1100-NH_v2_ed1.pdf the default IP address is 192.168.1.2
The quick start guide see https://download.zyxel.com/NWA1100-NH/quick_start_guide/NWA1100-NH_001.pdf should help you make an Ethernet connection to the NWA1100-NH for configuration.
The troubleshooting section of the talks about that the NWA1100-NH might be getting its IP address from a DHCP server, which in your case could the router from your broadband supplier.
It might be worth trying to disconnect the NWA1100-NH from your router, and then doing a factory reset to see if you can ping the NWA1100-NH on 192.168.1.2 IP address.
If you can ping it on 192.168.1.2 then you should be able to access the web configurator with a web browser (the user guide does not say that it is https) so just try putting 192.168.1.2 in the address bar
- if you get the login screen then admin with password 1234 should give you access.
I hope that this is helpful.
Kind regards,
Tony0 -
cannot find working download link for 2.12(AASI.3)C0 firmware
can someone help1 -
Hello @n_o
I haven't found that firmware as a user, but I know that it is needed because of OS vulnerability, see
Alternative you could consider if you wish is installing OpenWRT firmware, see
https://openwrt.org/toh/hwdata/zyxel/zyxel_nwa1100-nh
Kind regards,
Tony
openwrt is no option
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 353 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
