Vpn on a Wsq-50
Limpan
Does the WSQ-50 support vpn-tunnel?
How should I do?
Intending to use Nordvpn 0
https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=M-02809&md=Multy X (WSQ50) According to user manual, no.Limpan said:Does the WSQ-50 support vpn-tunnel?
I don't knowLimpan said:How should I do?
You may ask to NordVPN support how to install it on your devices.Limpan said:Intending to use Nordvpn0 -
There is an article discussing the VPN, if the protocol of the VPN can bypass the Multy, the VPN can work.
https://community.zyxel.com/en/discussion/6425/can-i-add-a-vpn-to-multy
And yes, I agree you can also ask NordVPN support how to install it on your devices.0 -
You can find your os version here and check if you download correct version
https://www.catalog.update.microsoft.com/Search.aspx?q=KB5010793
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
