Zyxel NAP353 showing update available but not updating
DelRatonRV
DelRatonRV Posts: 2 image  Freshman Member
Second Anniversary
Getting this error when trying to update NAP353 devices via Nebula portal.
"Failed to download the firmware : URL using bad/illegal format or missing URL"
I am able to update the Flex700 through Nebula portal. Current NAP353 version is showing as V6.25(ABEY.2). What is going on? How can I update manually?
  • DelRatonRV
    Second Anniversary
    It has finally updated. Had to reboot the Flex700 three times before it worked. This should not have to occur.
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    edited July 2022
    @DelRatonRV
    We're glad your problem has been resolved. According to our past experience, the reasons for seeing such a LOG include:
    1. Your AP can't connect to Nebula Firmware Server.
    2. DNS Server can't analyze the Nebula Firmware Server.
    3. Other network issues
    Since the AP has successfully updated the F/W, it means that the current network environment can operate normally. If the problem occurs again later; please open support to us again, we will enter your site to check it as soon as possible, and help you clarify and solve the problem.
    Or you can refer to this article to manually upgrade your AP
    Please check your password on your Nebula.(Side-wide>Configure>General Settings>password)
    And the latest firmware version can download from Zyxel.com.
    https://support.zyxel.eu/hc/en-us/articles/360003285540-How-to-upgrade-firmware-to-controller-Access-Point-by-FTP-
    Sincerely
    Zyxel_Jay
Nebula Tips & Tricks
