nsa320 won't setup
Thanks but that doesn't seem to be this particular issue.Upstream I said I turned on SBA - what I meant was I had turned on SMBv1. I wasn't aware of the versions but that is what I did.Glad you brought this up because it reminded me to turn it off now.0
I think I'm just going to get a new NAS.
DogByte said:I think I found the answer to this problem here.if by browse you mean it's default shares in disk exploerer then yes that will be a problem, for now you will need to enable smbv1 in your windows system settings.
nonobaddog said:Thanks but that doesn't seem to be this particular issue.Upstream I said I turned on SBA - what I meant was I had turned on SMBv1. I wasn't aware of the versions but that is what I did.Glad you brought this up because it reminded me to turn it off now.0
I have a 2 bay 6 TB NSA320 with 1000's of scanned slides on it. Haven't accessed it in years. Want to connect to Windows 10. Startup disc will not complete installation. Went to Powershell and it says SMB2 is active.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
