NR7101 vs iphone 5g speed
Posts: 64  Ally Member
edited January 2024 in Mobile Broadband
same location/position
same simcard
ookla speedtest
iphone: 750mbit download
nr7101: 210mbit download
because of better antenna, i would expect NR7101 to have better results then iphone.
whats going wrong here - any ideas ?
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
«13
  • Posts: 373  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Is it NSA or SA?
    Set your phone to 5G ON not 5G auto and check your speed at ookla again.
    What is your settings?
  • Posts: 64  Ally Member
    edited July 2022
    i have tried different settings , result is allways more or less the same.
    currently I have "NR5G-NSA / PS only"
    ( pure NR5G-SA does not connect at all )
    i also tried PCI Lock on all available 4G and 5G bands.
    also tried different APNs
    the NR7101 is outside, perfectly adjusted to the celltower.
    iphone is reaching 600mbit even inside ( open window without sight to celltower / on that position where photo is made )
    i am not shure how to check iphone connection details.
    anyway NR7101 should outperform it.
    edited July 2022
    edited July 2022
    Are you sure that tower is the right one for best speed?
    Try simcard from modem in your phone and check speed.
    yes , this is the closest tower, with 3500Mhz and not overbooked. also its antenna directon fits quite good. even fresnel zone is clear. this is why iphone gets 700-800mbit 15ms constandly.
    I will try different sim cards, and swap between both devices.
    (got a brand new sim last week)
    edited July 2022
    Remove all cellular lock and change settings like pic, try both 5G NR and 5G NSA.
    no connection on NR5G-SA mode
    ( not even after reset/reboot )
Welcome!
Welcome!
