NR7101 vs iphone 5g speed
n_o
same location/position
nr7101: 210mbit download
because of better antenna, i would expect NR7101 to have better results then iphone.
whats going wrong here - any ideas ?
same simcard
ookla speedtest
iphone: 750mbit downloadnr7101: 210mbit download
Is it NSA or SA?
Set your phone to 5G ON not 5G auto and check your speed at ookla again.
What is your settings?
i have tried different settings , result is allways more or less the same.
currently I have "NR5G-NSA / PS only"
( pure NR5G-SA does not connect at all )i also tried PCI Lock on all available 4G and 5G bands.also tried different APNsthe NR7101 is outside, perfectly adjusted to the celltower.iphone is reaching 600mbit even inside ( open window without sight to celltower / on that position where photo is made )
i am not shure how to check iphone connection details.
anyway NR7101 should outperform it.
Are you sure that tower is the right one for best speed?0
Try simcard from modem in your phone and check speed.0
Remove all cellular lock and change settings like pic, try both 5G NR and 5G NSA.
no connection on NR5G-SA mode
( not even after reset/reboot )
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
