vpn site to site
Hi @voip
Welcome to Zyxel community!
This problem is not due to the base pack since site-to-site VPN can be used in all organization types.
May I know what firewall model is your customer using?
Can you help to enable Zyxel support and provide the organization name for us to check? You can leave the organization name here or provide it to me via PM.
Please go to Help > support request > Zyxel support to enable
Zyxel Melen0 -
Both nsg50
name: STP Modena Tecnica
administrator privileges on
thanks0 -
Hi @voip
I check the VPN connection and found the site-to-site VPN is connected.
May I know if the problem is still there?
If yes, can you describe the symptom?
Zyxel Melen0 -
Hi @Donaldroy,
If you are using NSGs in all your sites, please reference this topic below to create:
[NEBULA] How to establish Site to Site IPSec VPN between Nebula Devices (NSGs) ? — Zyxel Community
If you not only use NSG but also USG FLEX/ATP in your sites, you also can reference this topic to create.
If you want to create site-to-site VPN between NSG and other devices, please reference this topic below to create:
[NEBULA] How to establish Site to Site IPSec VPN between Nebula and Non-Nebula devices ? — Zyxel Community
Hope it helps.Zyxel Melen0 -
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
