Running PiHole with Zyxel Multy X Wifi has certain issues.
Smoker14
Virgin Media Superhub connected to the main Zyxel Multy X in the lounge's WAN port in modem mode. There are 3 other Multy X devices operating as WiFi access points across the house.
One of these is plugged into an Ethernet port in the study and has PiHole installed on it.
I have DHCP Server turned off and a static IP configured on PiHole (which I reserve in the Multy X config).
Set the IP of the PiHole as my primary DNS server in the Multy X settings.
The Multy X re-my ip's entire network in less than ten seconds (EG taking from 192.x.x.x to a 10.x.x.x network).
https://getinfolist.com/2020/07/02/how-to-find-ip-address-on-windows/
There are some discussion about this issue, maybe its because the DNS server IP address is the same as lan subnet
https://community.zyxel.com/en/discussion/8495/problem-trying-to-run-pihole-with-zyxel-multy-x-wifi
https://community.zyxel.com/en/discussion/comment/26109#Comment_26109
Hello all,
I have now put this on the Consumer Ideas area of the forum at https://community.zyxel.com/en/discussion/13959/ability-to-run-pihole-with-multyx-and-have-a-local-dns-resolver-that-is-different-to-the-router/p1?new=1
- I could not find it as a customer idea request before now back to 2020.
Please give it a like there if you would like this feature to be added to the MultiX product.
Kind regards,
Tony0
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
