NBG6515 - unable to login after V1.00(AAXS.8)C0 firmware update
Tech99
Firmware update from V1.00(AAXS.7)C0 to V1.00(AAXS.8)C0
broke web management login.
Password which is/was used to login is 23 chars long.
Password is not overly complex, but contains;
- upper- and lowercase, numeric and other chars, from ascii range 33 to 122.
Tested this with other device, result was same - unable to login after firmware update.
I have the same issue -- after firmware update from V1.00(AAXS.7)C0 to V1.00(AAXS.8)C0 unable to login through web interface.Why is this faulty firmware still available for download?0
Hi @User9316
We'll have a new firmware that solve the issue, it will be released in next month.
We'll modify the firmware in the Download Library.0 -
Mine did the same when updating from V1.00(AAXS.8)C0 to V1.00(AAXS.9)C0.11 character password with Upper and lower case characters and numbers.
Hi @Random666
This issue will happen when upgrading to the firmware V1.00(AAXS.8)C0 or using the V1.00(AAXS.8)C0 firmware to do the upgrade.
Please reset the device and install again.0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
