NBG6515 - unable to login after V1.00(AAXS.8)C0 firmware update
Tech99
Tech99 Posts: 2 image  Freshman Member
edited June 2022 in Home Router
Firmware update from V1.00(AAXS.7)C0 to V1.00(AAXS.8)C0
broke web management login.
Password which is/was used to login is 23 chars long.
Password is not overly complex, but contains;
- upper- and lowercase, numeric and other chars, from ascii range 33 to 122.
  • Tech99
    Tested this with other device, result was same - unable to login after firmware update.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,405 image  Zyxel Employee
    Hi @Tech99
    We're working on this case,  will keep you updated.
  • User9316
    User9316 Posts: 1 image  Freshman Member
    I have the same issue -- after firmware update from V1.00(AAXS.7)C0 to V1.00(AAXS.8)C0 unable to login through web interface.
    Why is this faulty firmware still available for download?
  • Zyxel_Jerry
    edited July 2022
    Hi @User9316
    We'll have a new firmware that solve the issue, it will be released in next month.
    We'll modify the firmware in the Download Library.
  • Random666
    Random666 Posts: 1 image  Freshman Member
    Mine did the same when updating from V1.00(AAXS.8)C0 to V1.00(AAXS.9)C0.
    11 character password with Upper and lower case characters and numbers.
  • Zyxel_Jerry
    edited January 2023
    Hi @Random666
    This issue will happen when upgrading to the firmware V1.00(AAXS.8)C0 or using the V1.00(AAXS.8)C0 firmware to do the upgrade.
    Please reset the device and install again.
