User Configuration number of zones
since 4.72 is already available and contains an urgent vulnerability fix, I wanted to ask if you can provide me again a patched version 4.72 containing the zones-fix?
And I wanted to ask when we can expect a 4.80 version that finally fixes this bug with the zone-limitation?
Thanks & greets,
Daniel0 -
According to this post, 4.73 should be expected as "next release"Remember that 4.x devices are going EOL at the end of the year.
Hello @dnlk17,This zone-fix is added into V4.72C0 already, please refer to the Release noteDo you encounter this after upgrading to V4.72?Thank you.
Best regards,James0 -
Thanks for your feedback, and thanks for the hint @Zyxel_James
Sorry my fault, I've just upgraded to 4.72 and zone issues are gone. Thanks a lot guys!0 -
Hi @Zyxel_Emily,
I'm running v5.31(ABAQ.0) on my USG20-VPN and I'm facing the same issue. Currently I've 6 zones configured and trying to add a new zone I'm getting the error below:
-52011: Zones have reached the maximum number
Any update, solution or workaround to fix this issue? I need to add more zone.
Thanks and regards,
Marco0 -
The number of zone can very from model to model in my case I did have 15 then a firmware made it 14 checking it now with V4.72(AAAA.0)ITS-22WK28-r104687 your now able to have 16.
With the USG20-VPN being a low model you might not be able to make may zones like the USG40 can only have 8.
Is it a hard limit you might ask? No not really but likely the more zones the more processing is needed more then likely.
looking at the user_guide page 898 under the new name USG FLEX 50W you should be able to do 8
USG20-VPN_V5.31_Ed2.pdf (zyxel.com)
3529242,
Could you provide a screenshot that includes the User Configuration of 6 zones settings and the error message also?
Thank you.
James
Hi James,
you can find the screnshoot in attach. As confirmed by Peter in the user guide I can see a limit of 8 zone, but I cannot proceed after the current 6 zone.
Marco
Hello @3529242,Thanks for your feedback, we're checking the problem, and will keep you updated when there is any progress.James0
3529242,
We will fix this problem, however V5.32 is about to release, we will merge it to the next firmware version.
Currently, we could build a workaround firmware for you, please let me know if you need it, I will send it to you via private message, thank you.
James0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
