NWA210AX activate LAN Port
Niro96
Niro96 Posts: 56 image  Ally Member
Hello, I have two AP NWA210AX.
One is connected via LAN to the switch via POE. The second is connected by wireless on the ground floor. I now wanted to activate the LAN port in the NEBULA. Under AP settings I have LAN 1 VLAN 1 and PVID1. I then activated LAN under the AP. Unfortunately the haven remains. Can someone help me?
greeting
Marcus
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 513 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch
    According to your description,
    Since the NWA210AX model does not support the wireless bridge feature,
    The LAN port setup would only work on the Root AP, on the repeater AP (wirelessly connected one ) would not work.
    Please refer to the device function table with the below path:
    PATH: Nebula left sidebar “Help” >> Device function table
    Notice: Both the Root AP and Repeater AP are necessary to support the wireless bridge feature, or the repeater AP LAN port would not work.
    Let us know if there are other questions.
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • Niro96
    OK. Thanks for the explanation. If I connected the NWA210 to the router via LAN, the LAN port could work.
    greeting
    Marcus
Nebula Tips & Tricks
