NAS326 V5.21(AAZF.11)
Worked perfectly, thank you. Will there be an update when the issues with latest FW have been fixed and can be used again?0
Hi @ctggladiator, @Mijzelf @dHeinz, @zacki27101 @ikubuf
We will release firmware this month and the PHP issue will be fixed in this firmware.1 -
Thanks for helping get this working again. What I'd really like, and others too, I'm sure, would be to update ownCloud to a newer supported version (updating the database server), or add Nextcloud.1
dvbird said:Thanks for helping get this working again. What I'd really like, and others too, I'm sure, would be to update ownCloud to a newer supported version (updating the database server), or add Nextcloud.
Yes, that would be great!
In addition to that, I´d like to get a newer version of MySQL, I´m using kodi, which log file says:
"Your database server version 5.1.73 is very old and might not be supported in future Kodi versions. Please consider upgrading to MySQL 5.7 or MariaDB 10.2".
Hi @ctggladiator @Mijzelf @dHeinz @zacki27101 @ikubuf
The new firmware has been released.
You can find the firmware in the download library.
https://www.zyxel.com/support/download_landing.shtml#
Hello,thank you very much that worked for me.0
Yes the new firmware resolved the sql problem, however the NAS seeker no longer works, it no longer discovers the NAS. Is there a procedure to fall back on the firmware anywhere? Version 10 worked fine.0
Hi @wolfe4656
Since the NAS Utility is End-of-Life, the NAS utility is not available on the new firmware
https://community.zyxel.com/en/discussion/13907/nsa-starter-utility-eol-announcement#latest
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 322 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
