NR7101 stopped surfing
Luca789
Posts: 13 Freshman Member
Hi guys, I don't understand why it stopped working. it seems connected, ping works. onedrive seems working but I can't surf the internet.
I called ISP and I paid everything. I disabled IP passthrough and enabled it. nothing. I updated firmware. Any idea?
I
I update
I
I update
You have it set to router mode. Most people have set it for ip-passthrough mode. Have you tried if that works for you?
BrandSafway said:You have it set to router mode. Most people have set it for ip-passthrough mode. Have you tried if that works for you?BrandSafway said:You have it set to router mode. Most people have set it for ip-passthrough mode. Have you tried if that works for you?0
Hi @Luca789
The ping to 8.8.8.8 from within the NR7101 shows that it can get to the Internet via your ISP, because 8.8.8.8 is Google's public DNS server on the Internet.
- so the issue should be LAN related or the NR7101 settings.
So what do get if you try a ping 8.8.8.8 and tracert 8.8.8.8 from a client host on your LAN please?
- do your clients get an IP address automatically from the NR7101 using DHCP?
- i.e. an IP address in the range 192.168.1.2 to 192.168.1.254 ?
Kind regards, Tony0 -
Microsoft Windows [Versione 10.0.22000.795](c) Microsoft Corporation. Tutti i diritti riservati.C:\Users\luca>ping 8.8.8.8Esecuzione di Ping 8.8.8.8 con 32 byte di dati:Risposta da 8.8.8.8: byte=32 durata=70ms TTL=111Risposta da 8.8.8.8: byte=32 durata=64ms TTL=111Risposta da 8.8.8.8: byte=32 durata=81ms TTL=111Risposta da 8.8.8.8: byte=32 durata=89ms TTL=111Statistiche Ping per 8.8.8.8:Pacchetti: Trasmessi = 4, Ricevuti = 4,Persi = 0 (0% persi),Tempo approssimativo percorsi andata/ritorno in millisecondi:Minimo = 64ms, Massimo = 89ms, Medio = 76msC:\Users\luca>0
Esecuzione di Ping google.com [142.250.184.110] con 32 byte di dati:Risposta da 142.250.184.110: byte=32 durata=48ms TTL=111Risposta da 142.250.184.110: byte=32 durata=321ms TTL=111Risposta da 142.250.184.110: byte=32 durata=319ms TTL=111Risposta da 142.250.184.110: byte=32 durata=50ms TTL=111Statistiche Ping per 142.250.184.110:Pacchetti: Trasmessi = 4, Ricevuti = 4,Persi = 0 (0% persi),Tempo approssimativo percorsi andata/ritorno in millisecondi:Minimo = 48ms, Massimo = 321ms, Medio = 184ms0
ipconfigConfigurazione IP di WindowsScheda LAN wireless Connessione alla rete locale (LAN)* 1:Stato supporto. . . . . . . . . . . . : Supporto disconnessoSuffisso DNS specifico per connessione:Scheda LAN wireless Connessione alla rete locale (LAN)* 2:Stato supporto. . . . . . . . . . . . : Supporto disconnessoSuffisso DNS specifico per connessione:Scheda LAN wireless Wi-Fi:Suffisso DNS specifico per connessione:Indirizzo IPv6 locale rispetto al collegamento . : fe80::f989:be5d:3130:6ff%17Indirizzo IPv4. . . . . . . . . . . . : 192.168.15.207Subnet mask . . . . . . . . . . . . . : 255.255.255.0Gateway predefinito . . . . . . . . . : 192.168.15.118Scheda Ethernet Connessione di rete Bluetooth:Stato supporto. . . . . . . . . . . . : Supporto disconnessoSuffisso DNS specifico per connessione:0
Ipconfig result doesn't match with the ip address range!
Thanks @Luca789 for your reply.
It seems like something else is on your LAN, so that your Windows client is not directly using the NR7101...
Can you please do a tracert 8.8.8.8 or tracert google.com on your Windows computer, so that we/I can see if your Windows client is getting to the Internet via the NR7101 on 192.168.1.1 or not?
Kind regards,
Tony
tonygibbs16 said:Thanks @Luca789 for your reply.
Kind regards,
Tony
Hi guys, I solved the problem. I didn't know that the wifi of the nr7101 was only for configuration purposes. I connected my laptop with a cable to the router and it surfed fine.
sorry guys1
- 415 Beta Program
- 2.4K Nebula
- 145 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 239 USG FLEX H Series
- 267 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 247 Service & License
- 384 News and Release
- 83 Security Advisories
- 29 Education Center
- 3.2K FAQ
- 71 Security Highlight
