VPN100
I have a VPN100 configured for L2TP access. It works for most of the clients connecting to it except a very small number of people can't connect. Everybody is using Windows 10, and I can't find any reason why they're unable to connect. It says the connection was denied because the user name/password is not recognized or the select auth protocol is not permitted. But, they all have the same settings with the correct username/pwd. How can I troubleshoot this?
Hi @ScottiYou may have a check L2TP security setting on problem PC.Only left "PAP" option is enabled in L2TP Security setting.And also you can monitor the event log on your VPN100 to make sure client traffic arrived to VPN100 without problem.
I will tell them to try that today0
I ended up switch to the SSL VPN which seems to work better. Thanks for your help0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
