NWA50AX Reset Password
Hi @ErickkkkFirst, if you want to reset the AP, please press the reset button until the LED light turns to yellow. If your AP is not registered on the Nebula, your password will be reset.If your device is registered on the Nebula, when you reset the AP and it is connected to Nebula, your password will change Nebula password.You can see your Nebula password in the below picture.Wish it can help you.Zyxel_Jay1
Hello Zyxel_Jay, thank for your help.Its ok yet.1
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
