NR7101 DHCP issue
Daniel_TMC
Daniel_TMC Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
Hello! Have mounted 2 NR7101 at customers houses. At the first installation after one o to days the router in NR7101 starts to give units in LAN the same IP so their is some problems that it dont remember what IP that it has given to what units IPs to. so to fix that I needed to install a router behind the NR7101 than the problem was dissolved. An yes DHCP is enabled in the NR7101. I installed one in a new site and I get the same problem there Accespoint drops IP gets messed up totaly weird. Same with the first firmware (but it was wery bad speed) upgraded both to 100ABUV4C0 and its the same the routers DHCP is totaly messed up. tried reset but no it does DHCP bananas the only way is to set fixed IP on all things (no solution) or but a router behind. I have installed 4G LTE7409, LTE7480 and they workes lite charm but NR7101 is some firmware mess
  • Miaa
    Miaa Posts: 28 image  Freshman Member
    First Anniversary
    Hi Daniel_TMC , NR7101 IP passthrough be enabled by default, LAN unit will obtain WAN IP address from network side. Did you try disable IP passthrough to check whether improve the problem or not?
    (Go to web GUI>Network Setting>Broadband>Cellular APN>Modify APN#1>disable IP Passthrough)
  • nils_FR
    nils_FR Posts: 2 image  Freshman Member
    Hi Miaa, it was my problem too and disable IP passthrough work !
