ATP 100 Connection Not Working
PoulosEsq
I have an ATP 100 connected to business internet router in bridge mode on one side and a Net Gear Orbi mesh wi-fi on the other. The unit goes as far as a flashing sync light. The WAN light and LAN lights do not come up, and I can no longer get a connection. What to do?
Hi @PoulosEsq,
Could you kindly share your configuration via Private Messages?
Also, please also collect kernel debug log when issue agian.
- connect console port and log in
- input "debug kernel console-level 8"
- collect all output messages for us.
Thank you.0 -
Hi @kunz,
Did you mean the RMA ATP100w SFP port is bad ?
Have you changed the tranceiver to test ?
Kevin0 -
Hi @Zyxel_Kevin,
Yes the SFP port was defective as the RMA has pushed thru, just found out last night, many thanks.
kunz0 -
Hi @kunz,
Thanks your feedback, I received the issue from ticket system.
I will update the progress to Joseph.
Thank you
Kevin0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
