Connecting 2x Multi X through NWA55AXE --> one domain
uch
I am trying to set up two houses with about 50 yard distance working in the same network described in the picture below. I am bit confused: can I use Multy App or Nebule App to do that or should I use separate apps for each segment.
How should I configure the network?
Is there a tutor suggesting how to do that?
I am a novice with these type of networks.
Thank you!
// uc
Thank you!
// uc
Hi @uchThe scenario would not work in this case, the Multy X on the right side of the picture could not recognize the mesh on the left side.You can consider substituting the NWA55AXE on the right side in the scenario into the LTE series.
thx jerry - so you mean that I cannot plug the other NWA55AXE in Multi X LAN port and the other building NWA55AXE in Multi X WAN port and create a wireless bridge, which connects these Multies into the same mesh?0
Hi @uch
As the topology you provided, the right side of the Multy X is not able to recognize the Multy backhaul behind the mesh of NWA55AXE.
- 602 USG FLEX H Series
- 480 News and Release
