NAs540 used as a rsync DESTINATION
Alexpt0867
Hi guys, may i ask if someone knows how to enable rsync SERVER in a nas540 device ?
i would like to use a NAS540 as an rsync DESTINATION device.
thanks for your help
alex
alex
As far as I know the firmware doesn't support this. But if you are a bit comfortable with scripting, the package RandomTools has a rsyncd binary, and a directory where you can put start scripts. As far as I know the rsync daemon needs a file /etc/rsyncd.conf, which path cannot be changed. As /etc is on a ramdrive, the startscript should also copy the conf file to there (or create a symlink)
Thanks a lot MiJzelf,0
Great, but how to install RandomTools?0
- 441 Beta Program
- 293 Service & License
