NAS540 Still Repairing after 72 hours
Causingfire
I had a drive fail on raid 5 configuration. I replaced the failed drive and started the repair process. After the resync progress it is now at "repairing" for 15 hours.
Looking at dmesg and mdadm --detail; it looks like it finished.
Is there any other step to complete the process or did it finish and the UI is bugged out?
Have a look with top if e2fsck (filesystem check) is running. If not, and nothing important is active, just assume the webinterface is buggy.
I think the gui reads the content of /proc/mdstat to show the status.
/proc/mdstat doesn't show a recovery status, and the UI is still showing repairing...Is anything else I should check?
Thanks, I restarted the NAS and now it is showing healthy again
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
