usgflex 100 connected with nwa1123
Thank you
Carsten
According to your description the topology should be as below, not sure if you have switch or not.
If your USG FLEX acts as DHCP server, please configure the DHCP setting on the interfaces to assign IPs. The switch should setup all VLANs on both AP and USG connecting ports or configured as truck port to allow traffic.
The AP’s role is forwarding the traffic to the wireless that SSID with configured vlan interface. The only step is to assign vlan on SSID, you can check this article for details.
How to create an SSID on Standalone mode?
https://community.zyxel.com/en/discussion/13899
Thank you
Regards,
Bella
Thank you
Regards,
Bella
Thanks for the fast help.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
