Mesh with EX3301-T0 Multy M1
stmik
Hello
In the near future I will receive a EX3301-T0 router from my ISP. As this has WiFi 6 I plan on using it at my main router, but I would like to extend its coverage with a mesh-setup. Is it possible to use the Multy M1 (wsm20) as part of a mesh-network with the mentioned router and not just as an AP with a different SSID? I know they both have mesh-functionality, just not if they work together as planned.
I also know the EX3301 has a mesh AP in the same lineup, that model is however not readily available in my country.
Hope someone can help me out.
Kind regards
Hi @stmik
Multy devices can mesh with Multy devices, but not with other model series.
You can refer to the Table2 in Multy M1 User Guide PG10
https://download.zyxel.com/Multy_M1_(WSM20)/user_guide/Multy M1 (WSM20)_V2.40_Ed2.pdf
Zyxel
Hi @stmik
Zyxel
Thank you very much @Zyxel_Jerry
That's a real shame.I had the same question and had hoped there was a way around it.Are you saying there is no way at all, so forget it, or there might be.Hoping new owner of both...0
Hi @Viryabodhi
Multy series do support mesh, but the different Multy model cannot do the mesh.
Zyxel
Hi @William3542
Could you help to describe more details about your issue?
What model and the firmware are you currently using?Zyxel
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
