I can't enable sign in method?
Hi there,
Captive portal customization is free, supported models can do this. Actually, it is not related to PRO pack’ feature.
In the case you use some models as NWA50AX, NWA55AXE etc., they don't support captive portal. I attached a part of Device function table here as an example to let you follow easily.
You also can go to Help >> Support tools >> Device function table ( Zyxel Nebula - Device function table ) to know all the function of Zyxel products.
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
