Problem with WDS WAX510D as root with NWA1123-AC-HD
PeterUK
PeterUK Posts: 4,264 image  Guru Member
edited May 2024 in Wireless
USG60W as Controller V4.72(AAKZ.0)ITS-22WK28-r104687
WAX510D as root AP
Force Overwrite VLAN Config
Management VLAN ID 4091
uncheck As Native VLAN
NWA1123-AC-HD
This seem to of happened after I updated WAX510D to V6.40(ABTF.6) all seem to be working then some days past I could not log in to NWA1123-AC-HD and wifi when connecting whould not get an IP by NWA1123-AC-HD but WAX510D seem fine.
I rebooted the NWA1123-AC-HD that did not fix it rebooted the WAX510D then it started working and could login to NWA1123-AC-HD and wifi by it.
Then I got this and logs.
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    @PeterUK
    We’d like to know if your steps are upgrade USG60 from WK35 to WK41 then the limited AP status returns.
    Normally, it shouldn’t raise the status again unless the temp data not removed from AP so could you reboot AP and check if the status is clear or not?
    Thank you
    Regards,
    Bella
  • Zyxel_Bella
    Hi @PeterUK
    The WAX510D can be managed by USG60W but NWA1123AC-HD couldn’t.
    Since the title you mentioned WDS, do you configure WAX510D as root on controller and NWA1123AC-HD as repeater in standalone mode?
    From the logs, we saw a known issue recently been found on controller that limited AP status occurs after upgraded firmware. But it will not impact the service on the symptom AP so we’d like to confirm with you if above topology assumption is correct, then the repeater AP can’t be accessed after limited AP status raised?
    Please provide USG60W and both APs diagnostic files for us.
    Thank you
    Regards,
    Bella
    Yes the The WAX510D is managed by USG60W with NWA1123AC-HD as repeater in standalone mode.
    All seem fine but I think over some uptime the setup will fail and NWA1123AC-HD will stop working again. I have a TCP ping to it to monitor it.
    Will send you the files by PM
  • Zyxel_CSO
    Zyxel_CSO Posts: 504 image  Zyxel Employee
    5 Answers First Comment Friend Collector Eighth Anniversary
    Hi @PeterUK
    For the USG60W incorrect display WAX510D as limited AP status GUI issue, the fix is included in V4.72-WK35 firmware that will be available soon.
    Thanks for collecting the files, we’re investigating the diaginfo of APs to clarify what happened when repeater can’t be access. Will update you if any observed.
    Regards,
    Bella
    Zyxel Nebula Support
    edited September 2022
    I think its to do with the WAX510D firmware as connecting clients to the repeater stops getting a IP a reboot of the repeater did not fix it but a reboot of the WAX510D did.
    I have upgrade the firmware on USG60W to 22WK35-r105124 thats meant to fix limited ap and its still showing as limited.
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    Ouch.
    Just to update ZLD V4.72 WK41 with WAX510D still showing as limited
  • Zyxel_Bella
    @PeterUK
    Thank you
    Regards,
    Bella
    Cutting power to the AP to do reboot fixed it thanks
