NR7101 access point connection unstable
Luca789
Hi guys,
I connected 2 different access point to the router but the connection is completely unstable. I connect wifi with my android phone to the access point, it seems to work, the speed test works and I can surf. Unfrtunately after a while the esclamation mark shows up next the wifi icon and it stops working. after another while it starts again. I don't know. is there any setting that I forgot to configure?
Luca
Luca
I had similar issue, I also have two wifi access points in my network.
Reading through an Austrian lteforum I spotted that someone had the issue that the NR7101 drops all traffic when a new device joins the network and asks for an IP via DHCP.
You can test if you have this issue by opening up command prompt on a computer and do a command: ping 8.8.8.8 -t
Then enable e.g. wifi on your phone and let it connect and request IP. You should see the ping responses drop for some seconds.
This issue is present at least in 1.00(ABUV.4)C0.
I fixed the issue by changing the modem from routed to IP passthrough mode (bridged). I use my old 4G-modem as router for now.1 -
Yeah ok but it's a huge issue1
I updated the firmware to abuv6 and the issue was solved0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
