NR7101 Dynamic DNS and Ping
danielruppen
danielruppen Posts: 10
edited January 2024 in Mobile Broadband
Hi
I have setup Dynamic DNS (Dyn) on thge NR7101 and it works according to the NR7101 and as well I see updates on my Dyn hosts page
However when I try to ping the address it doesn't work. Every paket is lost. Ping is enabled under security settings
Any idea?
Regards
Daniel
  • n_o
    n_o Posts: 67 image  Ally Member
    edited September 2022
    same here
    i cannot get ping working , both in passthrough or normal mode
    remote passthrough-management is working https://ip:20443 and ssh on port 20022
    so public IP is ok
  • It's resolved. My NR7101 got a private IP address from the ISP. But after a phone call to the support they have now assigned a public IP address (called remote APN at Sunrise) and now all works fine
