Connect clients on LAN 1 to server on LAN 2
Hi @PeterUK,
You rock! I forgot it is typical triangle route in this scenario.
Thanks for highlighting the mistake.0 -
Thinking about it to not have “Allow Asymmetrical Route” checked on the USG60 a better option for that setup is to use “Use IPv4 Policy Route to Overwrite Direct Route” on the USG40 with this routing rule.Again this would be usefulUSG40 routing ruleincoming interfacemember LAN2destination 192.168.147.0/24next hoptype gatewaygateway IP of LAN1 gateway on UDG60SNAT none1
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
