Connect clients on LAN 1 to server on LAN 2
2»
  • Zyxel_Cooldia
    edited September 2022
    Hi @PeterUK,
    You rock!  I forgot it is typical triangle route in this scenario. ;)
    Thanks for highlighting the mistake.
    Thinking about it to not have “Allow Asymmetrical Route” checked on the USG60 a better option for that setup is to use “Use IPv4 Policy Route to Overwrite Direct Route” on the USG40 with this routing rule.
    Again this would be useful
    USG40 routing rule
    incoming interface
    member LAN2
    destination 192.168.147.0/24
    next hop
    type gateway
    gateway IP of LAN1 gateway on UDG60
    SNAT none
