NAS326 get more error: (401) and 100% CPU
dnbx
dnbx Posts: 10 image  Freshman Member
When using WebDav
periodically I got lot of errors.
Error refreshing Webdav folder Test The remote server returned an error: (401) Unauthorized.
And in process monitor WebDav using lots of RAM
RAM - 426mb
CPU - 85.2%
/sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
how to fix???
  • dnbx
    and sometime get this error
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    You can try with tool cyberduck to open a webdav server on nas.
  • dnbx
    edited September 2022
    with cyberduck and mountainduck is same problem.
    not show all folders and still get more (401) Unauthorized errors
  • ikubuf
    try with path \webdav\video
  • dnbx
    Webdav is working, but when I using it (delete folders,files) it has  stuck on 99% of deleting, and NAS starts using 100% CPU and stuck for 3-5 minutes. and got error when try login.
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    My guess is that you have a hardware error. Have you looked at the SMART values of the disk?
  • dnbx
    both HDD are fine.
  • anmi4345
    anmi4345 Posts: 9 image  Freshman Member
    First Comment Seventh Anniversary
    After Firmware Update to 521.12 it has to be: URL/r51253,/...
    Pls. check
