Nebula Firmware Update doesn't do anything?
CRU_Technologies
in Nebula
We have been using Nebula for some time, but recently the FW upgrade process, well, just doesn't do anything.
If I go Site wide, Firmware Management, I can see Upgrade available, I select upgrade now (the device is online), click Save, shows changes saved, but nothing happens.
This is for multiple clients, sites and devices.
Hi @CRU_Technologies,
May I know if your device's firmware status has the suffix "stable"?
If yes, please help to go to site-wide > firmware management to change the firmware type from "stable" to "latest" before you upgrade. Sorry for the inconvenience.
Zyxel Melen0
Zyxel Melen0 -
Ah OK, that has worked. Obviously that wasn't an option previously. Stable or Latest - possibly needs a better definition? Is latest a beta FW? Should Latest not be used in live environment?0
@CRU_Technologies if you're familiar with "lab firmwares" from Zyxel, you can get a gist what stable/latest could mean.In some hotfix/lab firmwares, Zyxel published corrections for vulnerabilities out of the release cycle; with "latest" option, something similar could be pulled if the network administrator wish for that.0
Hi @CRU_Technologies,The latest firmware is the firmware released recently. And you could use it in a live environment because it has the bug fixed and new enhancements.
The stable firmware is the firmware that has been released for a few months and no issue has been reported, we will mark it as a stable firmware.Zyxel Melen0
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
