Nebula Firmware Update doesn't do anything?
CRU_Technologies
CRU_Technologies Posts: 27
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Switch
image  Freshman Member
We have been using Nebula for some time, but recently the FW upgrade process, well, just doesn't do anything.
If I go Site wide, Firmware Management, I can see Upgrade available, I select upgrade now (the device is online), click Save, shows changes saved, but nothing happens.
This is for multiple clients, sites and devices.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,093
    image  Zyxel Employee
    Hi @CRU_Technologies,
    May I know if your device's firmware status has the suffix "stable"?
    If yes, please help to go to site-wide > firmware management to change the firmware type from "stable" to "latest" before you upgrade. Sorry for the inconvenience.
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
  • CRU_Technologies
    Ah OK, that has worked.  Obviously that wasn't an option previously.  Stable or Latest - possibly needs a better definition?  Is latest a beta FW?  Should Latest not be used in live environment?
  • mMontana
    mMontana Posts: 1,506
    image  Guru Member
    edited September 2022
    @CRU_Technologies if you're familiar with "lab firmwares" from Zyxel, you can get a gist what stable/latest could mean.
    In some hotfix/lab firmwares, Zyxel published corrections for vulnerabilities out of the release cycle; with "latest" option, something similar could be pulled if the network administrator wish for that.
  • Zyxel_Melen
    The latest firmware is the firmware released recently. And you could use it in a live environment because it has the bug fixed and new enhancements.
    The stable firmware is the firmware that has been released for a few months and no issue has been reported, we will mark it as a stable firmware.
    Zyxel Melen
Nebula Tips & Tricks
